Refrigerator Constantly Runs - Appliances - DIY Chatroom Home Improvement Forum
Old 10-20-2010, 01:56 PM   #1
Refrigerator constantly runs
Hi folks, I have a Magic Chef Refrigerator that never shuts off. I cleaned the coils and fan a few weeks ago and noticed since then it never shuts off.Could the temperature switch have gone? It's a model# GT19Y8FW .
bobthrutools is offline   Reply With Quote
Old 10-20-2010, 05:23 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
take temp reaadings in both units and report back
hardwareman is offline   Reply With Quote
Old 10-20-2010, 06:25 PM   #3
HVAC / Plumbing
Make sure your door gasket is sealing off / door closing all the way . Turn the t.stat to the lowest setting & see it it will turn off
kenmac is offline   Reply With Quote
Old 10-21-2010, 06:44 PM   #4
Seasoned DIYer
Rewards Points: 150
Make sure the defrost heater and control are working properly. If it is broken, evaporator air flow will be obstructed and prevent proper cooling.
If it is stuck on, it will try to battle eachother out with compressor.
HVAC_NW is offline   Reply With Quote
Old 10-22-2010, 06:26 AM   #5
if only since then;i would suspect that cond fan is now not working.
Jacques is offline   Reply With Quote
Old 10-22-2010, 07:51 AM   #6
Thumbs down
1. Simply find the knob that operates the timer and turn it until you hear the click. 2. Wait 22 minutes. 3. Check to insure that your refrigerator parts are working properly and the unit has come out of defrost mode and is back to normal operations. If your refrigerator parts are not in working order, and the machine is not out of the defrost cycle, you have a defective defrost timer which needs to be replaced.
aeon20 is offline   Reply With Quote
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 08:08 AM
runs and sanding oscarMadison Painting 1 02-24-2009 05:46 AM
PEX Manifolds: home-run to each fixture vs grouping runs? drh Plumbing 3 04-02-2008 03:44 PM
moving wiring runs in attic DoubleD07 Electrical 1 07-23-2007 06:44 PM
Remodeling upper...existing runs to the basement? wease Electrical 3 02-11-2007 10:49 AM
