Old 05-12-2014, 03:12 PM   #1
Rewards Points: 264
refrigerator cabinet??
I hope this is the correct area to ask this...
I am getting ready to build a cabinet around my fridge, the plan was to put a cabinet directly above the fridge, sort of like this. I used to work in a cabinet shop and from what I recall all the refrigerator cabinets where built like that. I was however, talking with a friend the other day and noticed the cabinet above his fridge was mounted about 8-10" up from the top of the fridge. He said that was because the carpenter told him the fridge had to be able to breath up.
We both agreed the vents are on the bottom, but now I'm curious.... Is it ok to place the cabinet as close as possible? I'll try to locate the manual, but who knows if I still have it. If it matters I have a whirlpool side by side.
Master Brian is offline   Reply With Quote
Old 05-12-2014, 03:43 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 2,290
I have built cabinets for years and the only time we couldn't put the cabinet above the ref was when it was a Sub Zero. The cabinets in our kitchen are built like those in the picture and have no problems.
New members: Please consider adding your location to your profile.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Master Brian (05-12-2014)
Old 05-12-2014, 03:48 PM   #3
Rewards Points: 264
Good to know. I didn't have any problems at my last place and I installed the cabinets there. Just figured better safe than sorry....
Old 05-12-2014, 04:00 PM   #4
cj133's Avatar
Rewards Points: 256
Depends on the design of the fridge.
I believe our 2011 Kitchenaid pulls air in from the front left side and blows it out from the front right side all along the bottom. To be honest the condenser design sucks but that's another discussion. On this style fridge which many are probably the same no, you don't really need clearance.
Now, if you take one of my 1933-34 Monitor Top refrigerators, those need clearance around and over the top as they use 100% convection to cool the condenser.
cj133 is offline   Reply With Quote
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
