Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-18-2012, 06:45 PM   #1
Refrig. not enough cooling top (freezer) or bottom bottom
Frigidaire Top Freezer Mount
FRT18PRH Model Number
18 Cubic Feet, About 12 years old me thinks.
Condenser on back of fridge.
There's a Cold-Coldest Dial in freezer compartment (I removed back wall & fan cover) that regulates quantity of air only. Not sure if there's any other thermostat in fresh food compartment
Compressor is running, and hot to touch. Not just humming, but seems to me to have the sound and vibration of a running compressor. Fan in freezer compartment is running full speed.
Evaporater, behind back wall of freezer compartment, has no frost on it at all.
Temperature is the same for upper and lower compartments.
Air flow to freezer compartment and fresh food, is unrestrictred.
Condensor on back of fridge is not dust covered - is clean.
No water accumulation in fresh food drawers or compartment.
No condensation in freezer compartment, or fresh food compartment.
Drip pan on bottom of fridge (mounted on top of compressor) is dry.
Thx much for any help.
justplumducky is offline   Reply With Quote
Old 11-18-2012, 07:26 PM   #2
Are the coils on the back hot?
Old 11-18-2012, 07:59 PM   #3
No joe~, coils are not hot. Maybe lukewarm if anything, but maybe not even that...
Thx for your reply. And I'm very happy to hear/read that you were born at a "young age."
Old 11-18-2012, 08:20 PM   #4
Your missing two digits on the end of the model #.
http://www.repairclinic.com/RepairHe...ot-cold-enough
Old 11-18-2012, 08:33 PM   #5
I'll have to check it again in the morning, thx.
Old 11-19-2012, 09:06 AM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
possibly low refrigerant charge. Pull the cover on the evap coil and see if you have a frost pattern evenly across the entire coil. If not you are low and most likely will be shopping for a new refrig.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-19-2012, 11:19 AM   #7
I don't know about your fridge but with the ge top freezer models that I work with, sometimes the fan motor gets a little slower with age. It's not really noticeable except that everything else checks out okay but the fridge and freezer aren't quite cold enough. Also, you notice that the fridge runs almost constantly. Again, I'm not familiar with your model but it's quite common with ge top freezer.
jfrotten is offline   Reply With Quote
Kenmore fridge not cooling but freezer is working perfectly. l.shemon Appliances 13 11-26-2011 04:50 PM
Ice building up in the bottom of the freezer in layers lyleogle Appliances 8 11-13-2010 12:27 PM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 08:59 AM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
Freezer odors - coming from blower/fan Richo Appliances 3 05-27-2009 06:26 PM
