Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-21-2011, 09:23 AM   #1
Refrig ice maker
Whirpool Refrig Ice maker. The water filter plugged up and after replacing the filter the ice maker would not fill up the tray. I put water in the tray and it made ice and shedded the ice but would not refill the tray.
Fred Swinnea is offline   Reply With Quote
Old 10-21-2011, 10:23 AM   #2
Refrig ice maker
not enough info.. did you use an OEM filter? off label stuff can be problematic. refrig came with a filter by-pass. try that, to narrow prob down. may have bad valve or blocked i/m feed line[ice in tube].
Jacques is offline   Reply With Quote
Old 10-21-2011, 09:39 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Refrig ice maker
did you purge the filter to get all the air out?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
maytag refrig. mod msd2456geq ice maker leak alwaysomething Appliances 3 03-13-2011 04:34 PM
Kenmore (Whirlpool) refrig ice maker problem lexort Appliances 16 07-01-2010 03:00 PM
Ice Maker Not Getting Water sgorak General Discussion 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
Kenmore Refrig. Temp. ? kourso Appliances 1 07-09-2007 12:37 PM
