-   -   Refrig ice maker (http://www.diychatroom.com/f47/refrig-ice-maker-120781/)
Fred Swinnea 10-21-2011 09:23 AM
Refrig ice maker
Whirpool Refrig Ice maker. The water filter plugged up and after replacing the filter the ice maker would not fill up the tray. I put water in the tray and it made ice and shedded the ice but would not refill the tray.
Jacques 10-21-2011 10:23 AM
not enough info.. did you use an OEM filter? off label stuff can be problematic. refrig came with a filter by-pass. try that, to narrow prob down. may have bad valve or blocked i/m feed line[ice in tube].
hardwareman 10-21-2011 09:39 PM
did you purge the filter to get all the air out?
