Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-02-2010, 06:11 PM   #1
Refridgerator broke down
My Amana Refridgerator is broken.
Model number is P1190903W.
I got some advice that the coil needs to be cleaned.
Trouble is that I do not know where the coil is at or what it looks like. Can anyone help?
The Ferret is offline   Reply With Quote
Old 01-02-2010, 08:01 PM   #2
I did a little hunting on the web and came across this.
http://www.wikihow.com/Clean-Refrigerator-Coils
So I did clean the coil and it was a messy job indeed.
Its still not working. The fan is not running and the coil does not heat up like its supposed to.
What next?
Old 01-05-2010, 12:29 AM   #3
What next?
call a pro. could be several things. Is the compressor running? which fan is not running? The fan under the unit is wired in parralel with the compressor. if the compressor runs the fan should run. Could be a bad temp control. Could be a lot of things.
chard is offline   Reply With Quote
Old 01-07-2010, 12:45 PM   #4
If you haven’t all ready got it repaired.
The fan under the bottom near the coils should be running if the compressor is running. If the compressor is running and the fan isn’t more than likely the fan is bad. If the compressor isn’t running you may have a control problem or maybe the start relay on the compressor is bad. This page will help
Last edited by Scuba_Dave; 09-30-2010 at 12:30 PM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
