-   -   Refridgerator broke down (http://www.diychatroom.com/f47/refridgerator-broke-down-60842/)
The Ferret 01-02-2010 05:11 PM
My Amana Refridgerator is broken.
Model number is P1190903W.
I got some advice that the coil needs to be cleaned.
Trouble is that I do not know where the coil is at or what it looks like. Can anyone help? :(
The Ferret 01-02-2010 07:01 PM
I did a little hunting on the web and came across this.
http://www.wikihow.com/Clean-Refrigerator-Coils
So I did clean the coil and it was a messy job indeed.
Its still not working. The fan is not running and the coil does not heat up like its supposed to.
What next?
chard 01-04-2010 11:29 PM
What next?
call a pro. could be several things. Is the compressor running? which fan is not running? The fan under the unit is wired in parralel with the compressor. if the compressor runs the fan should run. Could be a bad temp control. Could be a lot of things.
applianceman 01-07-2010 11:45 AM
If you haven’t all ready got it repaired.
The fan under the bottom near the coils should be running if the compressor is running. If the compressor is running and the fan isn’t more than likely the fan is bad. If the compressor isn’t running you may have a control problem or maybe the start relay on the compressor is bad. This page will help
