Refridge Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 12-11-2009, 08:07 PM   #1
Post
refridge problem
i have a new fridge amana side by side w/freezer on bottom. it leaks water from bottom. no water is hooked up to the ice maker there is no drip pan also. should every fridge have a drip pan?
pigstone is offline   Reply With Quote
Old 12-12-2009, 04:07 AM   #2
Too Short? Cut it Again!
I have never seen a fridge that did not have a drip pan. You need one as it is what captures water in the defrost process. Sounds like yours got separated in transit or something. It should not be a big deal for the place you bought it to get one.
Old 12-12-2009, 10:27 AM   #3
you have a drip pan. you just can't see it. it's probably cracked [only leaks certain times]. this will be covered by your warranty from factory[1-year]. it's a bear to change, if you haven't done any, so let them do it.
Jacques is offline   Reply With Quote
Old 12-16-2009, 02:36 PM   #4
granlois
I have a whirlpool icemaker that is not dispensing ice to a glass. Icemaker is making ice great. Help!
granlois is offline   Reply With Quote
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 09:19 AM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 10:15 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
