Reefer/freezer Water - Appliances - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 05:01 PM   #1
reefer/freezer water
I have a GE reffer/frezzer side by side with ice and water despencers. There is ice built up along the inside bottom back panel and when it run the defrost cycle water leaks out of the reffer door. Any idea?
askand is offline   Reply With Quote
Old 03-25-2012, 06:15 PM   #2
An old Tradesmen
Rewards Points: 7,786
Don't make duplicate threads about the same problem in the other forums, thank you.
Old 03-25-2012, 06:21 PM   #3
I just want help. what is wrong with asking?
Old 03-25-2012, 06:25 PM   #4
An old Tradesmen
The forum is split up to into categories. Lie Appliances, for refrigerator/freezers. And the people that frequent this forum, will know about your unit or problem.
People in the HVAC forum may have little to no experience with your appliance.
By keeping topics in their proper forum, it makes things easier for everyone. those asking the question, and those answering teh question.
Old 03-26-2012, 08:01 AM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
defrost drain is plugged up and frozen over. remove the back cover on the evaporator, melt all the ice in the drain trough and the drain. clean the drain tube real good and you should be good to go.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
