Recommendation For Washing Machine - Appliances - DIY Chatroom Home Improvement Forum
Old 10-15-2009, 01:56 PM   #1
Rewards Points: 252
recommendation for washing machine
I am in the process of running the lines to the top floor of my house for my washer and dryer. I love the front loading machines but I've heard so many bad things about how loud they can be along with excessive vibration. I see that Samsung has a machine that is supposed to reduce vibration - was wondering if anyone has a suggestion for a quiet machine or anything else that I should be thinking about. We are already planning on tiling the area where the machines will be and adding a floor drain.
mazzonetv is offline   Reply With Quote
Old 10-20-2009, 05:23 AM   #2
if you read the other posts on this you'll see i perfer G/E or Whirlpool [just think they built a better unit and easier to get parts and service if you need it]. they're both as quiet as one would expect a large appliance spinning at 1000 rpm to be...make sure your floor is reinforced to withstand the vibrations that come with these-[all]-front loaders... make sure you can access the rear for service....if the dryer is gas you'll need plenty of inlet air for the burner,so louver the door or whatever-don't seal the room...remember nothing lasts forever so don't install them and then build the room around them so you can't get them out when you replace them.--lot of thems-huh.
Jacques is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Is this the proper way to handle a drain cleaning machine? darsunt Plumbing 6 07-28-2009 05:52 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 08:25 PM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
