Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-06-2010, 07:38 AM   #1
Recommend Bath Light/heater/exhaust
reading reviews to pick a bath light/heater/fan is confusing at best.
for an ~8'x10' bath - i'd like one that is
  • fast and easy to install,
  • doesn't have switch limitations or special set-up
  • the heater or heat lamp won't melt the plastic or require special insulation (some seem to be fire hazards)
  • i read many reviews of several fans that indicate heater elements are going out in the second year.
  • one that doesn't through a circuit breaker as many seem to do.
  • i've read several reviews of people installing new units but soon going back to using space heaters.
also, it seems that putting a heater and an exhaust fan near each other on a ceiling is crazy. an IR fan that heated surfaces far away would be cool, but my experience is that they only heat surfaces w/i 5' or so. i guess i'll be looking at a double or triple switch since another light is already in there.
the problem seems to be that all these units are crap from China. I'm not finding much w/ goggle: "american made bath light/heater/exhaust."
Thanks All
rosco is offline   Reply With Quote
Old 07-07-2010, 06:52 AM   #2
i'm reading consumer reports. in doing so i've a stupid question: can the fan exhaust into the attic?
Old 07-07-2010, 10:21 AM   #3
Xtreme DIY'r
No, you need to exhaust it thru the roof or outside
Old 07-07-2010, 12:30 PM   #4
if i tied the venting into another bath exhaust what will make it vent outside w/o back-drafting into the other bath?
Old 07-07-2010, 02:05 PM   #5
It was a dark and stormy
Yoyizit's Avatar
Originally Posted by rosco View Post
for an ~8'x10' bath
8x10 x 8' high = 640 cu. ft. At 8 air changes per hour this is 640(8)/60 = 85 CFM.
Old 07-07-2010, 03:58 PM   #6
thanks Yoyizit. i found this on the consumer reports (i wish i had the subscription to it): "The Home Ventilation Institute, the industry’s trade association, has this sensible rule of thumb for most bathrooms: The fan should have airflow of one cubic foot per minute (cfm) for every square foot of bathroom area up to 100 square feet."
Old 07-10-2010, 07:46 PM   #7
What i did was install 2 separate units and 1 switch.
I bought the best fan-light combo i could get - made by Panasonic - and installed it over the shower [it's rated for it through a GFCI] - and exhausted it through the wall.
Then i bought a cheapo broan infrared heater - the 1 bulb version they also make 2 bulbs - and installed it in the area in the bathroom away from the shower since heaters are not approved over tub-shower.
My basement bathroom is small so the 250 watt infrared heats it up nicely. If you have a larger bath then a nice unit again made by Panasonic has the element kind with a fan to circulate the heat but it sucks up alot of energy - might have to use a separate circuit and switch for it unless you buy just the 1 combo with all in - heater-light-exhaust.
Either way the air MUST be exhausted to the OUTSIDE else you'll get mold water problems.
I wouldn't tie 2 bath exhaust fans to the same exit as 1 fan might overpower the other and blow air into the other unit. Drill the hole and separate outside vent it.
Charlie123 is offline   Reply With Quote
The Following User Says Thank You to Charlie123 For This Useful Post:
rosco (07-11-2010)
Old 07-11-2010, 01:01 PM   #8
THX! Charlie - i think i can access this particular portion of the attic. If so, i'm good until it comes to the electrical wiring.
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 06:05 PM
Tie into existing bath GFI circuit for new basement bath GFI? 8roty Electrical 8 07-28-2009 12:38 AM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 07:45 PM
Bath Box drainage all gone bad. HELP shwingirl Plumbing 14 01-03-2008 05:25 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
