Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-22-2009, 09:29 PM   #1
range vent
Can I run a range vent hoizontally about 9 feet through an outside wall,and will it be eficient?
casa is offline   Reply With Quote
Old 09-23-2009, 12:51 AM   #2
GetYourShineBox's Avatar
range vent
you can either run the duct out through the roof or through an outside wall. if you go out through the wall you will need a wall cap for your ducting. if you go out through the roof you will need a flashing and a vent cap. make sure to seal your outside duct cap with exterior caulk and if you go with the roof install use roofing tar to seal the flashing and make sure to seal your duct joints so you dont have air leaks with either polyurethane foam,duct tape or silver foil tape.
GetYourShineBox is offline   Reply With Quote
range hood vent vinman Roofing 6 05-07-2012 02:23 PM
Under cabinet range vent mounting problem biosfreak General Discussion 3 07-15-2009 01:36 PM
Installing range hood - wall vent DIYGST HVAC 3 01-04-2009 08:45 AM
Wall vent for over the range microwave JoeClark Building & Construction 3 11-29-2008 01:11 PM
Range Hood Vent powrus Appliances 2 11-08-2007 03:07 AM
