Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-20-2009, 01:43 PM   #1
Exclamation Range/Over Problem
Hello All,
Having a problem with my Whirlpool WGE83301 Oven (Canadian). Stovetop elements work fine, digital display works fine, but the oven is not heating up.
I turned the oven knob to 500degrees bake then broil, and tested the elements with a multi-meter, and no voltage passing through. Checked the continuity of the burners and it seems fine.
Any suggestions? Thanks in advance.
acrognale is offline   Reply With Quote
Old 10-20-2009, 03:43 PM   #2
GetYourShineBox's Avatar
Originally Posted by acrognale View Post
Hello All,
might be the t-stat
GetYourShineBox is offline   Reply With Quote
Old 10-20-2009, 03:47 PM   #3
How could I check if that's the problem? Also, is the thermostat the copper rod towards to top of the inside of the oven?
Old 10-20-2009, 04:44 PM   #4
it will look similar to something like this.
http://www.grgarrity.com/documents/i...Thermostat.jpg
you can do a continuity test.
i would also check your selector switch. refer to terminal numbers guide to check out the oven.
http://stoveconnection.com.au/store/...46431---01.jpg
Old 10-20-2009, 04:57 PM   #5
It most likely is the thermostat...those are easy to change out...that copper rod is a capillary tube thermostat....as the temperature increases...so does the liquid inside the capillary that changes the temperature of your setpoints on your t-stat.
Viper16 is offline   Reply With Quote
Old 10-20-2009, 08:06 PM   #6
As far as I can tell by opening up the switch panel is that thermostat is hard wired into the selector switch. I having tried taking the switch out, maybe it does disconnect underneath. In any case, is there a way to diagnose which part is actually faulty?
Old 10-20-2009, 08:07 PM   #7
Great explanation. Like I mentioned in previous post, is there a test procedure to isolate the thermostat being faulty, or is this one of those just try and replace it type of situations?
Old 10-20-2009, 08:27 PM   #8
the t-stat should have terminals you can test. is there a wiring diagram, or terminal labels on the selector switch?
Old 10-20-2009, 09:09 PM   #9
No their isn't any visible terminals. If I'm looking at the back of the selector switch where all the power and element terminals are, the t-stat actually runs in behind, between the glass, and the front of the selector switch. I might try pulling the switch off to see what it looks like.
I'm not sure if this helps. When I move the knob from the off position to the various temperature settings, it makes a click, and the light blinks, less brighter than usual.
Also, I had the range plugged in, and the knob set to 450degrees bake, and checked to see if any power was going out to the burners, and there wasn't. However, I checked the black wire(L1 on wiring diagram) that leads to the relay on the control board and there was power there.
According to my wiring diagram, my range has a Safety T-Stat, not sure if that helps at all.
Old 10-27-2009, 05:17 PM   #10
Turned out to be the relay
More On This Topic
The defroster grid on the rear window of your car is only painted on the glass. It gets damaged easily, and the smallest break in one of the lines can cause the defroster to stop working. Electrical disruptions also effect the performance of your... Read More »
Michael Raines with Expert Village. Okay, we've turned the power off. Let's take off our switch. Now, as I said, this one isn't connected to the terminals. It's connected through a push tube in the back, so you twist gently and pull then the wire comes... Read More »
So I'm going to actually connect the Mic to our Mic terminal. Here's a Mic we're going to connect. You can see, it's already coming out with our 1/8th inch mini plug, which is exactly what we need. Another thing about this Mic terminal is you can not... Read More »
Today, we're changing instrument cluster lights on a 96' Ford Explorer. In this clip, I'm going to demonstrate the proper service procedure for reinstalling your headlight and four-wheel drive knobs, shifting the vehicle back into park, connecting your... Read More »
Rice cookers are handy appliances and can save you lots of time and effort in the kitchen. Like other electrical devices, however, their circuitry tends to wear down over the years, sometimes until the cooker no longer works. When this is the case... Read More »
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 06:57 PM
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 05:57 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 08:26 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 05:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 03:51 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
