Range/oven Stopped Heating After Breaker Tripped - Appliances - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 12:37 AM   #1
Rewards Points: 77
Range/oven stopped heating after breaker tripped
Our oven and glass top range stopped working following a tripped breaker that we restarted. The clock and the indicator lights say that it's working, but it's not heating up. Ideas?
OurHouse is offline   Reply With Quote
Old 12-18-2011, 07:08 AM   #2
Check the outlet and make sure that you're getting 240.
jfrotten is offline   Reply With Quote
Old 12-18-2011, 03:53 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
you'll need to look at the outlet and then the cord where it attaches to the range. May even be a bad breaker
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-18-2011, 04:06 PM   #4
Military Mom of 4
Snav's Avatar
I'd call a service tech - what triggered the breaker? An internal flaw, a loose wire - etc. However much I love DIY when it comes to something such as an oven I'd make full use of the service warranty.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 12-30-2011, 07:47 PM   #5
Rewards Points: 77
After living off the microwave long enough, I'm now going to do this. I need to buy a digital multimeter, but I was running comparisons and some say they test continuity, while others test resistence and others test voltage. Is there a reason I'd want one kind of digital multimeter over another?
Old 12-30-2011, 09:14 PM   #6
MarginallyQualified
Rewards Points: 2,464
Originally Posted by OurHouse View Post
...some say they test continuity, while others test resistence and others test voltage.
multi-meter means that it tests multiple things
voltage, continuity, and resistance.
you don't need a digital output for any of these functions.
The best choice in basic testers:
link
Old 12-31-2011, 09:07 AM   #7
Yeah agree. Respectfully; if you have ask- don't buy one. call a pro for any electrical problems..for yourself just buy a volt stick-$10-20. that will tell you=hot/not hot.
Jacques is offline   Reply With Quote
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 04:31 AM
Faulty Breaker? bpm Electrical 4 08-09-2011 07:17 AM
Tripped breaker installing new light switch? tylermac Electrical 3 02-05-2011 05:57 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 08:48 PM
tripped breaker rookie50 HVAC 7 11-28-2006 03:40 PM
