Range Hood Wall Cap/exhaust Diameter - Appliances - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 11:23 AM   #1
range hood wall cap/exhaust diameter
Hi
Installing a new range hood (electrolux chimney style, 600 CFM), with through wall exhaust. In Toronto (cold climate). 8 inch round coming from integrated blower unit.
INstall recommends:
In order of preference, use1st. 10" round duct2nd. 8" round duct3rd. 3-1/4" x 14" duct4th. 7" round duct5th. 3-1/4" x l0" duct6th. 6" round duct
Having difficulty sourcing a wall cap >6 inch size... My question is:
Will using the small cap have any major drawback -- thinking mostly about noise or strain on unit. Dont really need the full 600 cfm power anyway, since it is over an induction cooktop (not gas). Any other considerations?
nocsec is offline   Reply With Quote
Old 01-02-2011, 07:54 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
call your local appliance store , a 6" round exhaust hood should not be a problem to get.
hardwareman is offline   Reply With Quote
Old 01-02-2011, 09:24 PM   #3
thanks for the suggestion; i haven't tried an appliance store
6 inch is not problem
is it 8 inch that i can not find locally at building supply
will check that out tomorrow
any input on whether the 6 vs 8 inch cap makes a real difference (since it is only going to be ~15in through the wall at that diameter (with remainder 8 inch)?
Old 01-03-2011, 10:03 PM   #4
firehawkmph's Avatar
Rewards Points: 1,822
Noc,
Do you have a heating supply store in the area that supplies the hvac tradesman? I have one nearby that has their own shop where they bend up most of the sheet metal fittings. I can buy small sheet metal items there, but can't buy a furnace per se, because I'm not a licensed heating guy. Also, are you doing anything for makeup air? 600 cfm is a lot to pull out of a house without having a supply of makeup air to take it's place. You don't want to start pulling air down your chimney or flues.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Alternative to range hood fan Richo HVAC 2 04-11-2010 03:43 PM
Installing Range Hood and Stainless Steel Backsplash oguevarra Remodeling 1 02-26-2010 05:01 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 05:06 PM
