Range Hood Questions. - Appliances - DIY Chatroom Home Improvement Forum
Old 07-10-2008, 10:31 PM   #1
Question
Range hood questions.
We're getting close to selecting and installing a range hood. (The kitchen doesn't have one now.) We're currently looking at a mid-priced unit from Broan. (aka: NuTone)
Is there any particular CFM's I should look for? The Broan is around 430cfm. I'm also concerned about the seal of the exhaust vent. What prevents heat and cooling from escaping out, and small critters from getting in? A simple "flapper" wouldn't seem to be adequate. Is it?
I would appreciate any thoughts and comments before we pull the trigger on a unit. Thanks all.
Artie
Artie2 is offline   Reply With Quote
Old 07-14-2008, 09:41 PM   #2
Rewards Points: 150
I,m not sure about the seal question but I do know that the general rule of thumb is CFM's should be at least 1% of the total max BTU output of all your range top burners combined.
So if you have four burners that max at 15000 BTU's thats 60000 total, thus requiring at least a 600 CFM hood. Hope this helps some.
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 07-15-2008, 06:55 AM   #3
Great info. Thanks handi.
Ours is about 25,000 btu's, so 430 should be more than enough.
Old 07-15-2008, 08:18 AM   #4
Just don't go so large as to have the blower stealing "combustion air" from gas appliances anywhere in the house.
Old 07-15-2008, 08:23 PM   #5
Thanks for the tip, but not a problem. The only gas in this house is after my wife makes chili.
range hood vent vinman Roofing/Siding 6 05-07-2012 01:23 PM
Range Hood venting questions Crashless Remodeling 5 04-13-2008 09:30 PM
Same Circuit: Range Hood, DW, and GD? atty_toconnor Electrical 4 04-08-2008 04:43 PM
duct a range hood into garage? jimb317 General DIY Discussions 8 01-30-2008 07:41 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 04:06 PM
