Range Hood That Mounts To Wall - Appliances - DIY Chatroom Home Improvement Forum
Old 04-13-2012, 11:52 AM   #1
Range hood that mounts to wall
Hello all,
I have a basement suite reno underway, and I am looking for a range hood (non-vented, for charcoal filter) that will allow me to attach it directly to the wall, rather than needing cabinets on top for support. The cabinets are already in place and the space above the stove is open, we will not be adding anything to it. I can't seem to find this product without going directly to very high end stainless steel one costing $800+. Does anyone know if there are regular range hoods that will mount in this fashion?
BeMurda is offline   Reply With Quote
Old 04-13-2012, 12:08 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by BeMurda
Hello all,
I don't think you'll find one.
Most are too front heavy to just be supported by the back.
How about a shelf secured to the cabinets on either side. You could make it a wine rack or the wife can put some cook books on it.
sublime2 is offline   Reply With Quote
Old 04-13-2012, 02:45 PM   #3
MarginallyQualified
Rewards Points: 2,464
Not a problem. The cheapo plain vanilla sheetmetal exhaust hoods are light enough to be wall mounted. Do use good hardware and hit at least one stud.
I've done this and used the top for the toaster oven.
Old 04-14-2012, 08:40 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Years age in a lake cabin I built I had the same issue, no cabinet over the kitchen range. I installed a wide wooden shelf using shelf brackets about 32" apart (hood is 30" wide). I secured the hood to the bottom of the shelf.
Coastal South Carolina
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Problems with range hood installation. darsunt Remodeling 9 01-06-2012 04:59 PM
Over the range microwave and offsetting 12 deep wall cabinets samotlietuvis Remodeling 4 09-24-2011 01:43 PM
range hood wall cap/exhaust diameter nocsec Appliances 3 01-03-2011 09:03 PM
Installing a range hood NewHandyman Electrical 1 08-10-2009 09:42 AM
