-   -   Range Hood Installation - Replace or Keep Existing Ducting (http://www.diychatroom.com/f47/range-hood-installation-replace-keep-existing-ducting-138850/)
sprusgoose 03-31-2012 03:35 PM
Hey all. I'm in the process of doing a kitchen reno and recently purchased a range hood which I planned to use as a re-circulating unit. However, in the process of the demo, I discovered the original range hood ducting buried under a cabinet! The ducting is intact and runs to the exterior wall so no problems there. This range hood says it "recommends" 6" ducting (not "requires") and the existing is a 5" duct. The unit only puts out 400cfm so my question is, can I stick with the existing 5" and just use a reducer to put it all together, or will this be considerably more restrictive than the 6" duct? Any advice or calculations are welcome. Thanks!
sublime2 03-31-2012 04:07 PM
Can't see why not.Your not moving that much air that the 1" reduction would affect it.
Ironlight 04-05-2012 03:27 PM
There are hoods that move 800cfm through 6" ducts, so I think you'll be fine attempting to move 400cfm through a 5" duct which is roughly 66% the area of a 6". With more restriction your blower won't be as efficient, and you won't get a full 400cfm, but I doubt you're burn out the motor which is the primary concern.
lubertwillis 04-17-2012 06:13 AM
I agree with sublime2. You can. On this site you will find all kinds of best range hoods.
