Range Hood Installation Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 05-22-2010, 03:34 PM   #1
Range hood installation problem
I've removed my old range hood because it no longer matches our new appliances and I seem to have discovered a slight problem. The electrical wire comes out of the wall and entered the old range hood on the back left side. Everywhere I go, all the range hoods I find all are set up to have the wire come through the right rear. The electrical wire only comes out of the wall about 9" so it is not long enough to work with a range hood that is wired up on the right side.
I cannot for the life of me find any range hoods (under cabinet mount) that get wired up on the left side. Does anybody know of any or have any suggestions? I'm stumped and I don't want to put the old one back up.
Lucas718 is offline   Reply With Quote
Old 05-22-2010, 07:43 PM   #2
DIY staff
Rewards Points: 7,174
Sounds like you need a longer wire---Can you figure out where that one originates?
Typically, it will come from the outlet directly below--the one to plug in the stove.(NOT A 220 V outlet)
You will find it --Pull a longer cable and the job is done.---Mike--
Old 05-24-2010, 06:18 AM   #3
if you can't pull new wire--9" should get you into cabinet. then box that and run new wire off the box to other side.
Jacques is offline   Reply With Quote
Old 05-25-2010, 06:47 PM   #4
Did that today. Worked like a charm.
Thanks.
Old 08-16-2010, 01:28 PM   #5
there are actually a few like that but it seems like you already solved your problem
BronzeGenius is offline   Reply With Quote
range hood through the wall - - -stud in the way pacifier1er Building & Construction 30 05-21-2013 09:23 AM
suggestions on contructing a range hood steve1234 Carpentry 15 08-30-2010 10:35 PM
Slide In Range Installation perplexed Appliances 4 01-26-2010 09:31 AM
range hood specs? homer12 Appliances 2 06-12-2009 04:53 PM
Same Circuit: Range Hood, DW, and GD? atty_toconnor Electrical 4 04-08-2008 04:43 PM
