Range Hood - Ducted Or Ductless? - Appliances - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 11:53 AM   #1
Rewards Points: 1,010
Range hood - ducted or ductless?
I'm looking at installing a range hood soon and was curious about the ductless hoods. Do they work well? Not worth a hoot?
I could install a ducted unit, but to connect one to the existing exhaust duct would take a lot of tricky ductwork with short, tight turns. So if the ductless ones work well that would make my job that much easier!
spaceman spif is offline   Reply With Quote
Old 03-14-2011, 12:02 PM   #2
Experienced
Jackofall1's Avatar
Ductless, does work as long as you keep the filters clean, ductless requires a carbon filter in addition to a grease trap style filter. The carbon filters are about $30 and need to be replaced say annually.
Mark
Edit - the advantage of ductless other than the obvious reasons, is, you don't pump you conditioned air out of the house.
Old 03-15-2011, 05:53 AM   #3
If you can install a vent to outside, while maintaing spec's, you'll be much better off. it's also a one time thing. although the recirculated type will pick up some of the particulates it will still just dump the air back into room..
Jacques is offline   Reply With Quote
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
Alternative to range hood fan Richo HVAC 2 04-11-2010 02:43 PM
ducted range hood: vibration and air coming out of top vent ilyaz Plumbing 0 04-09-2010 01:36 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 10:45 PM
Installing a range hood NewHandyman Electrical 1 08-10-2009 09:42 AM
