-   -   Range Hood Duct Size (http://www.diychatroom.com/f47/range-hood-duct-size-34082/)
BOUTYM 12-19-2008 10:02 PM
I'm adding a small kitchen in my basement and am installing a 24" stove and 24" range hood. My problem is that the location of the stove prevents venting of the hood directly through the wall. Additionally, I'm very limited on space where the hood ducting has to run to the outside. I can only fit 4" duct in the space. I know 6" is about as small as one should go, but I really don't have much choice but to run 4" duct. The duct length would be around 48".
I don't want to use a non-vented hood and frankly I think even with the lost efficiency of the smaller ducting it's still better than a non-vented hood.
Thoughts?
sawyerEd 12-19-2008 11:50 PM
Stove gas or electric? Output of fan ? Size of output? Are there air consuming appliances in the basement? You are creating a negative atmosphere which could cause these appliances to malfuntion or kill somebody. Go carefully here and get some professional advice.
BOUTYM 12-20-2008 06:34 AM
It's an electric range. There is a small oil fired boiler in the basement also. I understand about the negative atmosphere and could agree that it might be an issue with the recommended ducting, but using a 4 inch duct would actually result in less negative pressure since the range hood would be less efficient. The range hood I'm looking to use is rated at 190cfm with a 3 1/4 x 10 duct and 220cfm with a 7 inch round. I would be going from 3 1/4 x 10 into the 4 inch round duct.
