Range Hood - Appliances - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 05:51 PM   #1
range hood
my kenmore elite range hood keeps blowing its fuse ,I cleaned the entire hood put new fuse in and it blew it again and running for a few minutes.
petu is offline   Reply With Quote
Old 08-28-2012, 07:53 PM   #2
Bombastic Idiot
notmrjohn's Avatar
What else is on that circuit? The hood, with lights on shouldn't be pulling much over a couple of amps if that.
There could be a short in the wiring or in the motor. Since it ran briefly, the motor could be seizing up or the fan jamming causing it to draw amps or there could be a loose connection that gets jiggled into shorting. Turn off the circuit, open any access panels you can, take out the filter and take a look around. gently wiggle any wires, spin the fan, see if it turns smoothly. Could be that grease on motor or wiring is causing short. That's about all you can do without taking motor out and bench testing it. Except for a situation I know about where there were four lights, removal of two of them stopped fuse blowing. It didn't matter which two, so it wasn't a socket problem. Just drawing too much current. All I can figure is that it was severly under wired. That's all I can do. . Hopefully a real expert will see your question
notmrjohn is offline   Reply With Quote
Old 01-02-2014, 10:22 AM   #3
Same Problem
My vent hood has been working for three years and all of a sudden the lights stopped working but the vent fan continued to work. I took it apart and found a blown fuse and replaced it. It still didn't work and it blew the fuse. Checked the electronic board and found a burnt spot on the switch so I replaced it. It still does not work and again it blew the fuse. The only thing left to replace is the transformer. Could this be the cause of everything?
grod is offline   Reply With Quote
Old 01-03-2014, 12:29 PM   #4
Rewards Points: 1,300
possible. Test it with a volt/ohm meter and see what the readings are to be sure.
danpik is offline   Reply With Quote
Old 01-03-2014, 05:31 PM   #5
chitownken's Avatar
Rewards Points: 510
Check the light socket and the wiring going to it for a possible short. The heat, grease, and vibration can be pretty hard on the wiring.
chitownken is offline   Reply With Quote
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 06:19 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
Alternative to range hood fan Richo HVAC 2 04-11-2010 02:43 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 10:45 PM
Installing a range hood NewHandyman Electrical 1 08-10-2009 09:42 AM
