Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-21-2010, 12:25 PM   #1
Question
range and fridge next to each other?
I just got a new Samsung french door fridge delivered to replace my old 37 yr old Amana. I have to have the range and fridge next to each other, until I can remodel another area of the kitchen, to make space for the fridge. This may take a while to do. I realize that the oven heat will make the fridge work harder in the mean time. There is a little more than 1/2 in of space between them. Would it help to put a 1/2 in sheet of styrofoam in between them, in an effort to prevent heat transfer to the fridge?
Tudy is offline   Reply With Quote
Old 09-21-2010, 01:06 PM   #2
Although not necessarily a typical configuration, I personally doubt that the proximity of one to the other is going to be appreciably detrimental to either over the long run. Nevertheless, I would opt for as much air space as possible over anything that you might stuff in between them. More importantly, in my opinion, be sure to maintain the manufacturer's minimum spacing between the appliances and the wall behind them.
The Following User Says Thank You to DexterII For This Useful Post:
Tudy (09-21-2010)
Old 09-21-2010, 03:17 PM   #3
Tizzer's Avatar
At this apartment complex I work at, the fridge & stove sit side by side. Any where from an inch to 1/2 inch clearance. Been that way for years.
Tizzer is offline   Reply With Quote
The Following User Says Thank You to Tizzer For This Useful Post:
Tudy (09-21-2010)
Old 09-21-2010, 04:40 PM   #4
HVAC / Plumbing
I wouldn't put any styrofoam next to the range
kenmac is offline   Reply With Quote
Old 09-23-2010, 06:21 PM   #5
Yes, I wouldn't put styrofoam next to the range, for safety reasons. Just try to have enough space between them.
MagicalHome is offline   Reply With Quote
Kitchen Cabinet Suggestions + General Kitchen Suggestions ffmariners Interior Decorating 3 08-16-2010 03:41 PM
Galley Kitchen remodel- want input cbrc5eric Kitchen & Bath Remodeling 1 06-11-2010 12:00 PM
over the range filters toeey1 Appliances 2 02-28-2010 10:46 AM
Gas Stove Outlet and Over the Range Microwave theatretch85 Electrical 6 04-24-2009 09:25 AM
GFCI plugs in kitchen DeterminedMom Electrical 10 04-23-2009 11:42 PM
