R134A Port On GE Monogram Refrigerator - Appliances - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 03:14 PM   #1
Rewards Points: 508
R134A Port on GE Monogram Refrigerator
The appliance repair guy took a look at my refrigerator, but he couldn't hook up to the process port on the compressor (low side) because it didn't fit either his manifold or mine. Do you know what adapter to use for a GE monogram R134 port?
benjamincall is offline   Reply With Quote
Old 05-31-2012, 05:30 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
there should be no port unless it has been previously repaired, and then if it was done right it should not have been left in the system
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-31-2012, 06:06 PM   #3
Rewards Points: 508
I tried an r410a mini split adapter, but the thread pitch seemed wrong.
Old 05-31-2012, 10:16 PM   #4
#1 HAWKEYE FAN
still not sure why it has an access valve on it but it looks like a normal sized valve to me
Old 06-01-2012, 07:57 PM   #5
Rewards Points: 508
1/2 ACME Female x 1/4 MFL? Where might I find something like that besides a supply house (already tried)?
Old 06-01-2012, 08:28 PM   #6
Tired & Dirty
Rewards Points: 83
Install a solder on self piercing access port below that one.
page number 114 in the catalog on this link, these work very good. be sure to leak test after soldering on the line & before piercing the line. these are avaible in most hvac parts house.
http://www.ite-tools.com/uploads/eng...s_fittings.pdf
evapman is offline   Reply With Quote
Old 06-13-2012, 12:12 PM   #7
Rewards Points: 508
I felt a little uncomfortable using a piercing fitting, so I'll see if the adapters I ordered fit the process port.
I'm going to triple evacuate the system and add some Super Seal ACR.
Do I need to add or change oil after I evac?
Water line for new refrigerator? pa555 Plumbing 5 06-08-2012 06:06 PM
Question about 20amp outlet for my refrigerator Penguinfan Electrical 6 04-04-2012 07:36 AM
kenmore top freezer refrigerator problem. joanneh105 Appliances 3 06-13-2011 08:08 AM
4th of July Refrigerator DavePA Electrical 4 03-18-2008 09:16 AM
