Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-01-2009, 12:45 PM   #1
Quik Question about Washing Machine
The drain hose for the washing machine should be easily removable & adjustable right?
My sister is moving and we are having a hard time removing the drain hose. I'm guessing its stuck.
Home Depot installed it. Yikes i didnt mean to post in the painting section.
evol200 is offline   Reply With Quote
Old 01-01-2009, 11:40 PM   #2
forget about it, i'll cut off the hose and go buy a new one..
Old 01-02-2009, 12:25 AM   #3
The drain hose should fit loosely in the stand pipe.
If you're going to cut the hose, you'll need to either connect the new hose to the pump (and that might not be easy) or also cut the new hose and splice the cut end of the old hose to the new hose with a hose barb to hose barb fitting.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Washing machine lint filter Dragonladie Plumbing 4 10-19-2008 07:52 PM
Reclocate Washing Machine , drain question ekimak0930 Plumbing 2 09-14-2008 08:29 AM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
