Question On How To Permanently Remove A Gas Stove? - Appliances - DIY Chatroom Home Improvement Forum
Old 10-20-2007, 04:54 PM   #1
Ljj
question on how to permanently remove a gas stove?
What is involved in permanently removing a gas stove and capping the line? Is it something a knowledgeable do it yourselfer can do or does it have to be done by a licensed professional? Would a professional have to get a permit from the town? We don't want to get into any trouble, the stove was installed without a permit, the previous owner put an illegal kitchen in the basement in a house that wasn't zoned for it, which is why we want to get it out of there asap.
Ljj is offline   Reply With Quote
Old 10-20-2007, 07:17 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I would hope that they at least installed a shut-off valve in the gas line to the stove, and that it is functional. Turn it off, and cap off the valve connection for the line. You don't need to cap off the line...cap off the shut-off valve. Use teflon tape (usually yellow) approved for gas on the female threads.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-06-2007, 08:14 AM   #3
Rewards Points: 5,336
I would first find out what the requirements were to remove it. In NY they will have you remove the piping. Capping the pipe coming out of the wall would not be acceptable.
Ron
Old 11-06-2007, 09:16 AM   #4
The code department isn't going to give you a hard time for trying to get your new place into compliance. They won't bust you for asking how to follow the rules/undo someone elses mistake.
NateHanson is offline   Reply With Quote
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
Wood Stove Question econdave HVAC 6 11-15-2006 07:11 AM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
Tricky Wood Stove Question Mosca General DIY Discussions 7 12-22-2005 01:42 AM
