Question About Pipe Sealant And - Appliances - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 09:18 PM   #1
Question about pipe sealant and
I just moved and need to replace the current gas connector of my dryer. On the appliance side of the current gas connector, there is pipe sealant already applied. Will that prevent me from removing the connector? If not, can you direct me to an article that will show how to remove it if pipe sealant was already applied - should I use brute force with a wrench to remove it (kidding)? Do I need to buy a new dryer if it was permanent?
Thanks. =)
simply derp is offline   Reply With Quote
Old 05-04-2009, 09:39 PM   #2
Rewards Points: 150
Just put a wrench on to remove the fitting. It should come loose with normal effort.
Gary_602z is offline   Reply With Quote
Old 05-04-2009, 10:25 PM   #3
Custom Cabinet Maker
NOT being a smartass here but MAKE SURE the gas is OFF b4 anything else :}:}:}:}. As said above just normal wrench, use a second to hold back the nipple in the dryer so ONLY the gasline is removed. Use pipe sealant FOR GAS on the new one
skymaster is offline   Reply With Quote
Duct pipe question DIYGST HVAC 2 01-07-2009 11:03 AM
Sump pump drainage question famdog Plumbing 1 01-05-2009 01:42 PM
sizing gas pipe SNC Plumbing 3 12-10-2008 07:33 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
