Queen Quilt (90x94) In GE 3.5 Cu Ft Front Load - Appliances - DIY Chatroom Home Improvement Forum
Old 10-10-2013, 11:21 AM   #1
Rewards Points: 208
Queen Quilt (90x94) in GE 3.5 cu ft Front Load
can i wash a flat queen quilt (90x94) in my GE 3.5 cu ft front load washer? the quilt is fairly flat. the instructions say that the max load for linen is: 2 flat queen sheets, 2 fitted queen sheets, and 4 pillow cases. the label on quilt says to use commercial washer.
what do you think?
washer in question: http://salestores.com/gegeneralele316.html#.UlbFuBCGdGg
Uploaded with ImageShack.us
Scully is offline   Reply With Quote
Old 10-27-2013, 01:41 PM   #2
Rewards Points: 81
Only way to really know is to see if it fits in without stuffing it. My initial thought it that it might fit. The problem with trying to wash it if it doesn't fit (other than not coming out clean) is the comforter could be damaged because there isn't enough space for it to move. I would not put it in a washer with a standard agitator.
MaineLL is offline   Reply With Quote
Old 10-27-2013, 07:39 PM   #3
Rewards Points: 142
IMO, I would follow the label on the quilt, and use a commercial washer & dryer. Tried it in ours one time, Kenmore 3.5cuft. We had to end the cycle immediately and take it to the commercial laundry. Never again. It didn't work well for us.
jmon is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 06:31 PM
Front load washers sturmnacht Appliances 2 08-10-2009 05:59 PM
Can this circuit handle the load seahawk2000 Electrical 8 01-05-2009 09:12 PM
Front Load Washer handy man88 Appliances 3 07-01-2008 11:16 AM
