Protecting New Tile Floor? - Appliances - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 10:21 PM   #1
Protecting new tile floor?
What do people recommend when moving a big and heavy new fridge across a 2 week old tile floor? What do people usually put down to cover it and prevent any scratching etc? Just curious what people do? Thanks.
ingeborgdot is offline   Reply With Quote
Old 11-18-2010, 05:16 AM   #2
Seasoned DIYer
Rewards Points: 150
They have these furniture mover thing you put under the legs of furniture/appliances. It's made of materials similar to milk jug. There's even one kind that has bolts that is meant to screw into appliances, which I'm guessing means the threading is standardized.
The first thing to do is clean very well and vacuum any carpet nearby, so you minimize the amount of sand and use one of those furniture mover pads.
HVAC_NW is offline   Reply With Quote
Old 11-18-2010, 06:12 AM   #3
DIY staff
Rewards Points: 7,174
I use 1/4 inch plywood--Cut the 4x8 sheet into 3 pieces---keep moving the pieces ahead of the appliance.
Old 11-18-2010, 07:36 PM   #4
Rewards Points: 282
These work well for a fridge if you have two able bodied men. http://www.amazon.com/gp/product/B00005TPUZ They don't work so well going up and down stairs though.
Jim F is offline   Reply With Quote
Old 11-18-2010, 08:21 PM   #5
There will end up being a dolly used but my wife has been talking to other people and some of the other horror stories she has heard about the appliance people and the things they have done to their floors is crazy. She doesn't want it scratched or any black marks from wheels put in the grout. We just had 2 new garage doors put in and installer damaged our door jam around the garage doors. Now they are going to have to come and fix the steel casing around the door which won't be a small job. The last appliance people put a big dent in our new cupboard drawer and it has to be replaced. We just don't want to take any chances with our tile.
Old 11-18-2010, 08:33 PM   #6
Seasoned DIYer
Rewards Points: 150
Hire a mover. They're much much better at maneuvering things in than contractors or appliance installers.
Old 11-19-2010, 06:22 AM   #7
DIY staff
1/4 inch ply and masonite are cheap---
Old 11-19-2010, 06:32 AM   #8
I am using some painters drop cloth and then putting some masonite on top of that. Should be fine.
The Following User Says Thank You to ingeborgdot For This Useful Post:
oh'mike (11-19-2010)
Old 11-19-2010, 07:19 AM   #9
Professonial appl repair guys carry something on the truck to preclude floor damage. accidents do happen but if your friends had that many problems i'd switch servicers. first thing a pro servicer does is check the floor out....newer refrig wheels don't mar the floors, as long as you just pull straight in/out. use something [masonite] that's real thin and long enough to allow plenty of access to rear once it's pulled out. if the floor protector is too high you'll have a hard time getting it over the hump [1/4" is high]..cracked tiles from refrig rolling out are caused by improper installation of the tile-floor wasn't properly leveled prior to tile being put down.
Jacques is offline   Reply With Quote
Old 11-21-2010, 08:11 AM   #10
Seasoned DIYer
Rewards Points: 150
He might not have a choice.
Kenmore *cough* *cough*. Their warranty repair providers have had reputation as being the lowest bid scums.
Old 11-21-2010, 09:59 AM   #11
Well, it all went off without too much of a hitch. The only thing they did was scratch the inside of our new cupboards when putting in the line for the dishwasher. Not much I can do about that but it sometimes happens I guess.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 06:49 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 07:03 PM
Kiwi tile for woodshop floor? rbh Flooring 2 08-20-2006 03:44 PM
