Propane Hot Water Heater - Appliances - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 10:34 AM   #1
Indentured Servant
propane hot water heater
I need a new one, and I need one that vents out the side of the house and not through a chimney. What kind of options do I have? I don't want to spend for a tankless because of the old, small diameter plumbing lines in the house. Should I just go with electric?
jackpine is offline   Reply With Quote
Old 09-05-2013, 01:12 PM   #2
Rewards Points: 758
You need a power vent model. These have a small blower that pushes the exhaust out.
They're more expensive than an electric model but since they have a faster recover rate you can often use a smaller size.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
jackpine (09-05-2013)
Old 09-05-2013, 02:17 PM   #3
MarginallyQualified
Rewards Points: 2,464
How much ceiling height do you have?
(iow... c/would a couple of 45's be made to work?)
Old 09-14-2013, 05:38 PM   #4
Indentured Servant
Looks like I will be going for an electric water heater. Power vent is expensive, don't know how long we will be owning the home, can't put a vent through a rim joist without a power vent, etc. My choice I would live here forever, but wife has other plans. I can always do it later, buy a couple hundred dollar electric and call it good for now. Thanks for the help.
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 12:50 AM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Propane hot water heater philmeister Plumbing 3 04-29-2007 07:20 PM
