Propane Cook Stove - Appliances - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 09:21 PM   #1
Question
Propane cook stove
I'm planning to install a new cook range in my hunting cabin. I note that the stove has a regulator of its own. To connect it to a 100lb propane bottle, what else do I need by way of a regulator at the bottle?
ThanX, Jim
A. Lobb is offline   Reply With Quote
Old 02-04-2012, 09:27 PM   #2
Rewards Points: 582
your supplier should have it set up to handle normal appliances you need a 2 stage regulator....
The Following User Says Thank You to ben's plumbing For This Useful Post:
A. Lobb (02-04-2012)
Old 02-05-2012, 03:36 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
two stage regulator at tank. Is the stove converted to LP?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
A. Lobb (02-06-2012)
Old 02-06-2012, 02:22 AM   #4
propane stove
Got high capacity regulator installed at 100lb tanks location. Less than six foot to range which I plumbed with black iron 1/2" pipe. No issues. I pressurized system and it held steady for 20 minutes. Yellow shut off ball valve on inside wall and 18" flex hose to back of stove. Stove came with kit and instuctions to convert to LP. No issues. Stove top and oven work fine even with both going at same time. Now I'm on the hunt for a 2 tank setup so I can install a second 100lb bottle. Any thoughts as to should the 2-way switch be automatic or manual? Bottles are located on southern side of house tucked well up under eave, even so I plan to build a simple "shed" to keep bottles looking new longer. ThanX, Jim
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 05:42 PM
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 06:23 PM
Cook Stove Outlet - 3 prong old range vs. 4-prong new range Patricia C. Bai Electrical 2 12-20-2011 03:21 PM
gas (propane) cooktop off a BBQ tank pstock Appliances 0 06-26-2010 10:21 AM
Diy propane stove help LAFORD1986 Appliances 1 01-03-2010 01:52 PM
