#1 |
Problem with water/ice on GE Frigerator
Model: TFX24ZRS
Over the weekend, I hooked this frig up to a water supply line after not using the water or ice maker for the past year. Foolishly, I didn't test the water, I just assumed it would be working. After several hours, it had made very little ice. After seeing this, I tested the water dispenser and barely got a drible. I perceded to try and get water for a couple of minutes assuming that there may be air in the line but it's delivery never improved. During my attempts to get water, one time it started following at a full rate, just as you would want (For approximately 3 seconds) then I heard some clunking noises from the back of the frig and it went back to a drible. I disconnected the supply line and turned the water on with no issues, it is pumping plenty of water. Does anyone have any thoughts as to my problem could be? I would appreciate some help trying to diagnose potencial issues. Thank you for your help. |
#2 |
Diesel Fitter
Solinoid valve! Unplug ref. before you touch it some are line voltage. Some have a screen you can clean but they're pretty easy to replace.If you wanna go hi-tech, tap it a couple times with the handle of a screwdriver it may free up.
#3 |
Thanks for the advice. I ended up replacing the valve and it's working properly now.
| Display Modes | |
| furnace problem | captjack | HVAC | 8 | 11-23-2007 12:15 PM |
| Post-Tension Slab Problem Advice/Help | Mike McBride | Building & Construction | 2 | 01-09-2007 02:51 PM |
| A/C Thermostat Problem | therumblefish | HVAC | 7 | 11-01-2006 09:08 PM |
| Drywall, Mold Problem due to Leaked Water | june03 | Building & Construction | 2 | 10-31-2006 08:24 AM |
| Problem W/ Power after Switching Outlets... | G19-Fanatic | Electrical | 17 | 08-28-2006 02:55 PM |
