-   -   Problem with water/ice on GE Frigerator (http://www.diychatroom.com/f47/problem-water-ice-ge-frigerator-7221/)
Bigman610 03-19-2007 05:03 AM
Model: TFX24ZRS
Over the weekend, I hooked this frig up to a water supply line after not using the water or ice maker for the past year. Foolishly, I didn't test the water, I just assumed it would be working. After several hours, it had made very little ice. After seeing this, I tested the water dispenser and barely got a drible. I perceded to try and get water for a couple of minutes assuming that there may be air in the line but it's delivery never improved.
During my attempts to get water, one time it started following at a full rate, just as you would want (For approximately 3 seconds) then I heard some clunking noises from the back of the frig and it went back to a drible.
I disconnected the supply line and turned the water on with no issues, it is pumping plenty of water.
Does anyone have any thoughts as to my problem could be? I would appreciate some help trying to diagnose potencial issues. Thank you for your help.
mikemy6 03-28-2007 02:23 PM
Solinoid valve! Unplug ref. before you touch it some are line voltage. Some have a screen you can clean but they're pretty easy to replace.If you wanna go hi-tech, tap it a couple times with the handle of a screwdriver it may free up.
Bigman610 03-29-2007 03:52 AM
Thanks for the advice. I ended up replacing the valve and it's working properly now.
mikemy6 03-29-2007 01:25 PM
no charge
