Problem With Washer Machine. Need Help - Appliances - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 02:21 PM   #1
Problem with washer machine. Need help
Just recently, drain water splashes out of the stand pipe when the washer rinses. I have to stop the washer several time to let water drain away.
I guess it is becarse of unclogged stand pipe. How do I fix it.
Thank you in advance.
dukect is offline   Reply With Quote
Old 02-06-2010, 06:34 AM   #2
common problem; due to lint buildup in that pipe. if you don't want to call a plumber you'll have to snake it yourself. only problem is; that lint gets like concrete so be careful.
Jacques is offline   Reply With Quote
Old 02-06-2010, 03:26 PM   #3
I agree, it is lint buildup, and needs some rugged snakey equipment.
billy_bob_3 is offline   Reply With Quote
Old 02-08-2010, 09:52 PM   #4
Rewards Points: 150
is it fixed ???
comp is offline   Reply With Quote
Old 02-11-2010, 11:31 AM   #5
Rewards Points: 530
What kind of pipe do you have for drainage? A small pulsator might clean the drain for you. Actually considering the p trap, the pulsator may not work. I would still try it as it will keep pressure in the pipe and might work the blockage out.
If the cleaning of the drain does not solve the problem, you might want to also make sure the vent pipe is clear.
GE Washer will not perform final spin joeycranston Appliances 6 01-18-2010 11:06 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Ge Washer Model # Gf900483g Help Help Help WOW12344 Appliances 1 04-16-2008 09:51 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
