Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-08-2011, 08:46 AM   #1
problem with ice maker...
I have a 2 year old Frigidaire with a built in water dispenser and an in freezer ice maker(no ice dispenser on door). I shut my water off recently when i went on vacation. When I turned the water back on the ice maker quit making ice cubes. The water dispenser works fine. The splines that move the cubes into the ice bin rotate but no ice cubes are produced. The shut off bar that rests on the cubes is in the lower "on" position.
I have no clue here. Thanks in advance for any info
dbldee20 is offline   Reply With Quote
Old 07-08-2011, 08:50 AM   #2
DIY Hack
Mr Chips's Avatar
Did you shut off the ice maker as well ( raise the bar to the off position?)
If you left it on, the pump motor probably ran constantly trying to pull water into the cube tray and just burned out.
If it's still under warranty you might forget to mention the water turned off for a couple weeks part
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
dbldee20 (07-11-2011)
Kenmore (Whirlpool?) Ice maker problem reddog6 Appliances 4 10-09-2011 07:11 AM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 07:35 PM
Kenmore Under Cabinet Ice Maker Problem Allstar Appliances 3 07-26-2009 11:51 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
