Pressure Washer Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 08-23-2013, 10:59 AM   #1
Rewards Points: 47
Pressure Washer problem
I didn't realize I did it but last time I tried to start my pressure washer, there was a huge up-spout from the discharge side of the pump. I guess I accidentally broke off the soap suction "T" and now water is shooting out. How could I go about fixing that without putting on a new pump? Do you think JB Weld would work or should I try to tap it and put a new screw in attachment in there? Thanks for the help.
tucker0104 is offline   Reply With Quote
Old 08-23-2013, 01:32 PM   #2
Rewards Points: 22
You may want to post a picture, or at least a make or model number; otherwise, it's anyone's guess. Like most mechanical devices, there are part sources, so barring something real unique, JB Weld would not be my first choice. Have you used it previously this summer? Is it possible that it froze over the winter? Reason I ask is that they do typically have a replaceable freeze plug.
Old 08-23-2013, 01:35 PM   #3
Rewards Points: 47
It is the nipple that broke off. I will put a picture on tonight. Thanks for the recommendation.
Honda pressure washer not making pressure brandon1023 Tools 1 07-23-2012 06:29 AM
Campbell Hausfeld 2030 Pressure Washer Problem 68rs327 Tools 3 11-09-2011 11:04 AM
Hot water pressure problem (unusual situation) tanna Plumbing 2 09-03-2011 09:17 AM
electric pressure washer on well water chippie Plumbing 1 07-10-2011 02:42 PM
Home water pressure problem ATLdrew Plumbing 13 04-24-2009 12:17 PM
