Preheating Time For Oven - Appliances - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 10:38 PM   #1
Preheating time for oven
I recently moved into a new condo where there is a self cleaning oven in the stove.
When I preheat the oven it takes 21 minutes to reach 400 degrees, only take about 5 minutes in another stove at my daughters.
I figure something is wrong, it is a digital stove, no fuses.
Am I correct in thinking this is way too long to preheat?
Terri311 is offline   Reply With Quote
Old 03-09-2013, 10:49 PM   #2
Rewards Points: 83
What kind of oven?
Look it up on the MFG web site. Call or E-mail customer service.
Its possible there is a relay out on the power control board causing only one element to work.
mech_gui is offline   Reply With Quote
Old 03-09-2013, 10:50 PM   #3
I remember the instructions of my 5 year old oven saying 15 minutes to preheat. Mine is on the small side. I wouldn't worry. Ovens are known to become hotter than their knobs indicate over time, which in my opinion is worse than this.
Dorado is offline   Reply With Quote
Old 03-10-2013, 10:42 AM   #4
Rewards Points: 216
you "may" have an "energy efficient" stove. meaning, it used less energy and takes longer to get up to speed.
Fix'n it is offline   Reply With Quote
Old 03-10-2013, 10:50 AM   #5
747
registered
747's Avatar
Rewards Points: 534
Seems like a long time to me. I had a similar problem years ago with my gas wall oven I needed to replace a part which was located around the electronic ignition. It was small box. I don't remember what it was called. My over preheats to 400 in 5 minutes or a little less
747 is offline   Reply With Quote
Old 03-10-2013, 11:06 AM   #6
Thank you everyone, I would not wonder if I did not have another stove in another residence that does reheat to that temperature in 5 minutes.
Another thing I noticed is that the elements in the oven never get really red, and neither do the top elements.
It is a Moffat range
Old 03-10-2013, 11:56 AM   #7
Girl with a Hammer
Sounds like you may need to have someone take a look at your oven. Overtime, it's normal for the heating element to be replaced. How long have you had the oven by the way?
dixongal is offline   Reply With Quote
Old 03-10-2013, 12:28 PM   #8
Rewards Points: 216
my wife says it takes about 10 mins for our new LG to heat to 400deg.
Old 03-10-2013, 01:06 PM   #9
I don't know how old the stove is, it was here when I moved in and it looks very new.
Old 03-10-2013, 02:56 PM   #10
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
15 mins is about the norm. Most ovens use the bake and broil elements to preheat. If it is cooking fine after the preheat I wouldn't be to worried about it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 09:13 PM
My first time playing (literally) with mains power Red Squirrel Electrical 16 05-16-2012 03:58 PM
shelves and cure time 7echo Painting 5 04-02-2012 09:27 PM
How do I change the time? MNsawyergp Site Help and Suggestions 4 02-14-2012 07:25 PM
Low budget concrete patio, sections at a time... vertigoelectric Flooring 0 01-29-2012 05:13 PM
