Possible To Retrofit On A Pilot Safety Valve To An Antique Range/oven? - Appliances - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 02:20 PM   #1
Question
Possible to retrofit on a pilot safety valve to an antique range/oven?
Hi there,
I have a beautiful old range that I received through a family member as a hand-me-down that I'm attached to. It's an old antique Wedgewood 4 burner 36" range that is built like a tank, and has one high output burner. Absolutely love how it looks. Since it's from the 1950's, it's all gas. There looks to be a 1/2" pipe and just the burner valves and thermostats attached to that solid pipe that runs in an L along the front and left of the range. The thermostat is the original Wilcolator Type C. It has no safety vavles or regulators.
Has anyone heard of anyone adding a pilot safety valve to this type of oven to prevent from burning off your eyebrows if the oven pilot dies? (e.g. a White Rodgers 764-742 http://www.drillspot.com/products/68...fety_valve?s=1 ). Possible/safe/not to code? Worth it or not worth it?
Also, in this case, it would be simple to add this to the gas input pipe and just run the thermocouple into the oven, as opposed to placing it on the pilot tube.
Thanks!
crm90 is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Need advice for gas hot water problem, please!! YerDugliness Plumbing 20 08-11-2008 11:17 PM
