Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-27-2011, 12:08 PM   #1
Portable AC Recommendation?
Does anyone have any portable air conditioner recommendations?
Living in Southern California in a small two-story townhouse.
Anne_J is offline   Reply With Quote
Old 05-27-2011, 01:07 PM   #2
When you say recommendations, are you looking for energy efficient? Quiet? Most high powered? I've done a lot of work with portable ACs, so if you give me some more info, I can probably help.
AlAtkin is offline   Reply With Quote
Old 05-27-2011, 01:17 PM   #3
Wire Chewer
Red Squirrel's Avatar
Look at one that has two pipes, an intake and an exhaust. The ones with only an exhaust are actually causing indoor air to go outside, and pulling outside air in. Since the compressor and condenser are in the unit, they need to be cooled so the resulting hot air needs to go outside, but it's very inefficient if it's using indoor air to cool it as this air needs to be replaced. That only occured to me after I bought my 1 ton unit. I modified it so it takes outside air to cool the compressor and increased it's efficiency like 4x. Some are designed like this, so that's your best bet if buying one.
Old 06-10-2011, 11:54 AM   #4
Thanks for the recommendation, I'll check it out.
Old 05-11-2012, 02:00 PM   #5
I know this is a bit of a resurrection but if your still looking for a portable air conditioner when things start heating up this summer take a look at consumersearch.com. They generally are a decent source of unbiased reviews because they simply aggregate reviews from websites. Unfortunatly they don't have any two hose units listed in their reviews for whatever reason. Two hose units are indeed more efficient and I'd recommend one if you can find it in your price range. I'm assuming window air conditioners are out of the question because of some sort of ordinance or restriction? Window units also tend to be a bit more efficient than portable air conditioners because the compressor sits outside of the house and heat from that stays outside.
Air-N-Water_EA is offline   Reply With Quote
Tags
Portable table saw stand baldeagle51 Tools 3 11-14-2010 09:04 PM
2FT water in my basement, Need help finding a good portable sump pump willowgirl Plumbing 9 03-03-2010 11:12 AM
Adapter for portable gas stove? ilyaz Plumbing 0 02-04-2010 12:33 PM
Portable saw Question Gettingintoit Tools 10 11-03-2008 08:45 AM
Portable air conditioners; who's got one? (No draining! Yet most say draining req'd?) Deck Appliances 1 07-16-2008 11:33 PM
