Please Help With This GE Washer! - Appliances - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 02:39 PM   #1
Please help with this GE Washer!
I have a ge washer, model is WCSR2090D5WW. Everything works fine
until it gets to the final spin cycle. Sometimes it works, some it does not.
I can get it to work by flipping the water level switch (pressure switch) back
and forth several times. This will always get it to kick in to gear. I replaced
the pressure switch thinking it was bad but it is still doing it! The machine will just be stuck on draining ( I hear the draining noise but everything has already drained out!) The draining will continue until I either move the load selector switch around or shut the machine off myself. Anyone have any ideas what the problem may be?? Could it be the timer??
downtick is offline   Reply With Quote
Old 02-06-2012, 06:28 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
I believe i told you in your previous post of about a month ago that the pressure switch would not fix your problem. So now that you replaced it anyway did you try the other thing I suggested??
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-06-2012, 06:31 PM   #3
the switch was only $15, was worth a shot. I guess you hinted at the timer. I guess that is what is next then.
Old 02-06-2012, 06:56 PM   #4
Rewards Points: 582
yes its the timer ..replace it....
The Following User Says Thank You to ben's plumbing For This Useful Post:
downtick (02-06-2012)
Draining laundry sink into washer stack? glamgirrl Plumbing 33 12-31-2011 03:02 PM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 03:41 AM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 06:29 PM
