Plastic Tubing OK For GE Refrig/freezer? - Appliances - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 07:35 PM   #1
Plastic tubing OK for GE refrig/freezer?
My GE refrig/freezer which cost about 1100 quit after at about 2 years from a coolant leak. (Since it was in seasonal home, had run less than a year so was out of warranty). When GE repairman came out, he said I needed to replace the plastic tubing which had been used to connect the water line because it would leak in future. He doesn't do that, so I'm trying to sort out if it needs to be done.
I'm having basement done and plumber can do it next time out, but the contractor said plastic is what is commonly used and wasn't sure it was necessary.
Opinions-should it be changed?
canoes is offline   Reply With Quote
Old 03-03-2012, 08:23 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
CHANGE IT! Plastic water lines like to develop small pin holes in the the middle of the nite or when your away for a few days
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is online now   Reply With Quote
Old 03-04-2012, 08:28 AM   #3
So does it need to be changed to copper? A plumber who was changing the hot water heater thought a better/harder plastic would work.
Old 03-04-2012, 08:58 AM   #4
Ravenworks's Avatar
Yes use copper,and while your at it install a ball valve for a shutoff, I hate those saddle valves,they are a problem waiting to happen.
Ravenworks is offline   Reply With Quote
Old 03-04-2012, 04:40 PM   #5
#1 HAWKEYE FAN
yes copper tubing is best
Old 03-04-2012, 07:36 PM   #6
Thanks!
Redgard vs 6mil Plastic Sheeting for tiling amodoko Remodeling 0 01-18-2012 12:57 AM
PEX Brass Fittings Turning Inside Tubing After Cinch Clamped GeeJay Plumbing 1 03-01-2011 10:16 AM
PEX Brass Fittings Turning Inside Tubing After Cinch Clamped GeeJay Plumbing 1 03-01-2011 08:06 AM
Buried Copper LP Tubing Earnie Plumbing 1 02-22-2011 09:22 PM
Plastic plywood, Plastic sheets, Plastic decking Spud Building & Construction 1 10-16-2009 05:43 AM
