Pipes Freezing - Appliances - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 10:46 PM   #1
Pipes freezing
My heat went out tonight and I can't get anyone here until tomorrow morning. The temp is going down to zero. Do you think my pipes will freeze in one night?
Foxm04 is offline   Reply With Quote
Old 02-03-2011, 10:52 PM   #2
Rewards Points: 27
Just to be safe, I would turn off the water at the main in the house and then drain the pressure off the water lines in the house at the lowest point on your water lines. Make sure you do both the hot and cold lines.
MBatson is offline   Reply With Quote
Old 02-03-2011, 10:59 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
I'm pretty sure you'll be alright until morning
hardwareman is offline   Reply With Quote
freezing pipes / bad insulation plumber red Plumbing 10 01-30-2010 06:46 PM
Questions about ambient temperature and freezing pipes cellophane Plumbing 3 12-16-2009 09:53 PM
Freezing pipes in master bathroom need a 993 Plumbing 8 11-29-2009 07:10 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
How to keep attic pipes from freezing in winter with gable vents ErikKratz HVAC 7 07-11-2008 10:32 PM
