Pipe Wrapping - Appliances - DIY Chatroom Home Improvement Forum
Old 10-28-2010, 09:32 PM   #1
Pipe wrapping
I want to wrapping the elbow which leaking. But i don't know which material are suitable for that. The spec given are:
Pipe spec: 2", A106 Gr B sch 40
Pipe component: Elbow, 2" LR, A234 WPB sch 40.
Design pressure: 6 kg/cm2.g
Operating Pressure: 3.5 kg/cm2.g
Design temp: 270 degree
Operating temp: 160 degree
Process medium: Low Pressure Condensate ( Vapor+liquid form)
Really hope that anyone can suggest the material used for wrapping it or any solution for it
hizami is offline   Reply With Quote
Old 10-29-2010, 09:48 AM   #2
HVAC / Plumbing
wrap it with what ?? If it's leaking. take it apart & make the repair
kenmac is offline   Reply With Quote
Old 10-30-2010, 07:50 PM   #3
Yes, change it out. You'll be fussing with it constantly if you don't.
Oops! is offline   Reply With Quote
Old 10-30-2010, 08:58 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
If you want something temporary, keep it simple. Duct tape or hot glue might work. Keyword: temporary. Best to take it apart and fix as suggested.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Pipe need to be dry when wrapping teflon tape? thisisbrianly Plumbing 5 09-27-2009 09:29 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
