Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-25-2013, 03:29 AM   #1
payne high effenciency furnace model 9g9yab
Is this furnace supposed to make a constant humming noise when it is turned down. It is very annoying. I'm really don't like this new furnace. It puts out lots of cold air! Anyone have any suggestions? thank you
akeen45 is offline   Reply With Quote
Old 01-25-2013, 10:11 AM   #2
Post your question under HVAC section so pros will see it.
You'll need to verify that your FAN setting on thermostat is set to Auto setting and not On setting. Verify that you get enough heat when unit operates.
diyorpay is offline   Reply With Quote
Payne gas furnace - blower fan running continuously Ed40 HVAC 0 02-05-2011 03:19 PM
payne furnace prob drisco HVAC 8 01-31-2011 09:17 PM
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 09:36 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
High Eff. Gas Furnace..? Kyle HVAC 17 12-16-2007 12:17 PM
