Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-21-2012, 08:16 AM   #1
Overflowing Washer
Why won't my washing stop filling? It just fills and overflows. Model RCA YBXR1060V1WW
Katie424 is offline   Reply With Quote
Old 07-21-2012, 09:19 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Overflowing Washer
a few differnet things that can cause this. First thing to check is the water valve itself, if you can get the machine to stop filling by turning the power off to the machine then the problem is not the valve itself. Second would be to get access to the pressure switch and check it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-28-2012, 09:58 PM   #3
Overflowing Washer
Check if the Pressure Switch Hose came off first.
Pedrin is offline   Reply With Quote
Old 07-29-2012, 01:07 AM   #4
Overflowing Washer
I've sometimes found the hose to the pressure switch gets clogged and won't allow any pressure up the hose.
Protocol. is offline   Reply With Quote
Old 07-29-2012, 07:37 AM   #5
Overflowing Washer
Find the preasure switch and see if the little hose is full of water. It will be fuss because their is water in the tub. Pump all the water out. Now take off the hose. Let all the water drain out of the hose. Now reconect to switch. The switch works off of air to the switch and not water filed hose. If the hose is cracked their would be water around it . Just look and see. Just do the above. If you had a long hose the same size you could hood up to the swtich and blow air you should i belive here the switch activate. After the above is done and still not working the switch could be bad . The switch is on when no water is in the tub. Now when preasure is enough the switch open's and shut's off the water valve. good luck
del schisler is offline   Reply With Quote
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 12:00 PM
Washer Drain Overflowing - fixed but... Weird_T_Figure Plumbing 0 02-06-2012 11:50 AM
help, washer overflowing drain Jesse40583 Plumbing 1 05-28-2011 04:31 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
overflowing washer drain pipe? mcasso Plumbing 2 07-26-2010 08:13 PM
