Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-23-2011, 05:30 PM   #1
over range microwave smaller than space
How to install 30in microwave in 36in space over cooktop?
Joellen is offline   Reply With Quote
Old 02-23-2011, 05:46 PM   #2
Retired G.C.
Kind of odd to have a 36" space, But not a tough issue, the best way is to center the Micro in the space, it install by the back plate and the top so support is not an issue. Then get material that matches you cabinets and install 3" pieces on each side, scewing them in fron the inside of the cabinets next to the micro.
CharlieO is offline   Reply With Quote
Old 02-24-2011, 08:24 AM   #3
You can buy the filler strip for your model from manf...you can also buy a 36" m/o..it's still just a regular size but panel[on left]comes already attached-looks nicer..
Jacques is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Bad smell in crawl space. John_W General Discussion 28 10-20-2011 11:24 AM
Over-the-range microwave with high power range? SecretAsianMan Appliances 2 03-08-2010 02:52 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
Range hood and microwave shelf install??? osueric27 HVAC 2 01-05-2009 01:01 AM
