Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-24-2009, 06:48 AM   #1
over the range microwave oven
how do I remove an 1993 Amana OTR microwave oven.. thank you
cmellinger is offline   Reply With Quote
Old 12-24-2009, 08:22 AM   #2
Remodeling Contractor
There should be two bolts in the upper cabinet above this unit. Unplug the electrical cord and then remove these two bolts. You should now be able to tilt the front of the unit and lift the back off of the support bracket.
Old 12-24-2009, 10:07 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
There also may be two long bolts through the front of the unit.
Remove the exhaust vent louvered cover above the microwave to check for boltheads threaded into the wall bracket behind the unit too.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-24-2009, 01:36 PM   #4
Household Handyman
A great big "Amen" to Mike's statement. I was asked to remove/replace an OTR unit recently and ran into this. We removed two screws which were through the bottom of an overhead cabinet floor, lifted until I thought I was permanently injured, and had pried behind the microwave until I thought the wall may cave in. No paperwork saved on this unit. My son just happened to remove the louvered panel above the actual cooking space and behold, there were the two bolt heads. These bolt went all the way through the microwave and into the metal plate bolted to the wall behind the unit. When the second screw was removed, the unit almost fell on me, those two locking tabs behind the unit at the bottom saved it. Valuable lesson learned and will be remembered. Merry Christmas, David
Over the range Microwave geeman Appliances 6 08-04-2012 07:56 PM
HELP. I really need some advice on how to remove an over the range microwave! justmeee Appliances 9 12-24-2009 04:47 AM
Above Oven Microwave Oven - Maganatron Burned Out chats72 Electrical 7 12-31-2008 02:19 PM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 01:14 AM
