Over the range Microwave
I want to install a over the range microwave. But just looking at it, i think the micro wave will be to low. is there a way to move the cabinet above the range up so that the microwave isn't to low? Thanks
Do you have air space above the cabinet over the range?
Is it an electric or gas range? Check with your local Building Inspection department for code. Check the installation instructions that come with the unit that you're buying. Mike |
If you have room, yes you can move it. The tops will not match the others. May look funny.
Its a electric range. lots of room above cabinets. thanks for the info guys.
2 Attachment(s)
But it is my house:thumbup::thumbup: Attachment 9139 Attachment 9140 |
thanks SDC, thats not bad looking. sure will save counter space gonna do that. mahalo
Thanks so much. I had the exact same issue and had no idea what to do. It worked perfectly.
| All times are GMT -4. The time now is 06:51 PM. |
