Oven Won't Warm Up - Appliances - DIY Chatroom Home Improvement Forum
Old 02-07-2009, 10:22 AM   #1
sweaty
Rewards Points: 276
Oven Won't Warm Up
My electric oven from 1995,a Maytag, model # cwe4200acb, serial # 10967663mh, won't warm up. The bottom element doesn't seem to get hot. How do I fix this?
sweaty is offline   Reply With Quote
Old 02-07-2009, 01:03 PM   #2
You could sart by checking the elemnt for continuity. Mine just cracked one day, lites out. When I when to lift it I saw one section was cracked through. If you use it a lot food spills seeem to weeken it as well as expansion and contaction.
Chemist1961 is offline   Reply With Quote
Old 02-07-2009, 01:13 PM   #3
Rewards Points: 2,906
The first three things to do are as follows:
1. Inspect the bottom (bake) element and see if there are any discoloured or "rough" spots on it. The heating element wire is inside that bake element, and if the heating wire burns out, it'll normally leave a rough or discoloured spot on the outer jacket.
2. Check the heating element by holding it as it warms up. If it remains totally cold, it's probably either a bad switch or a terminal to the bake element burnt off. If it gets warm, but not at all hot, it's probably that one of the fuseS or circuit breakerS to the stove is burnt out. Because the stove is a 220 volt appliance, there will be TWO fuses or circuit breakers going to it. Most often the two breakers or fuses will be connected together so that you can't remove or trip one without removing or tripping both. If you have a multimeter, check for continuity across the fuses or voltage across the circuit breaker. A warm, but not hot, heating element normally means that the heating element is only getting 110 VAC instead of 220 VAC.
3. If nothing's panned out so far, remove the two fuses or trip the two circuit breakers to the stove, pull the stove away from the wall and remove the dozen screws or so to remove the back panel from the stove. Look for a wire burnt off at the bake or broil element terminals.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Oven Blew Up at Connector with Element cynthiap Appliances 6 10-31-2015 10:48 AM
Oven - junction box in cabinet DIYGST Electrical 5 11-13-2008 04:23 PM
Oven Building sinr98 Electrical 3 09-14-2008 12:43 AM
