-   -   oven wont light (http://www.diychatroom.com/f47/oven-wont-light-124845/)
porkchop 11-28-2011 04:16 AM
oven wont light
i have a Maytag Stove model # 31000paw when i turn on the oven the pilot light gets bigger but the oven wont light. Any ideas on what it might be Thanks
hardwareman 11-28-2011 07:53 AM
pilot assy. may need cleaning/ blown out. If its not that, then gas valve will need replacement.
del schisler 11-28-2011 08:59 AM
It could be the Thermocouple if it has one . The little nut may need to be tighten? Call some one that may know about stoves about this.
porkchop 11-29-2011 04:12 AM
pilot light stays lit the burner just wont light
del schisler 11-29-2011 06:37 AM
if that is the case than the gas valve may be bad i belive that was mention in another post. Mite be time to call in a pro for that?
baudretsch 07-16-2013 09:39 PM
It's probably the thermocouple
It's probably the thermocouple.
However, the thermocouple is an integral part of the gas valve, located at the very back of the lowest compartment. It may take a little research to find the correct one, but it's a lot cheaper than a new oven.
Check that the thermocouple is clean first.
sublime2 07-16-2013 09:41 PM
1 Attachment(s)
One possibility.......
Attachment 73911
MTN REMODEL LLC 07-16-2013 10:58 PM
Guys, if it were the thermocouple, wouldn't the pilot have been shut down?
Sounds like the gas valve to me.... at least on some gas valves, there is a relatively inexpensive part of the solinoid that often needs replacement if the stove is old. I ran into it on one of my kids old stoves.... can't remember exactly how I tested for it, and the exact name, but in my kid's circumstance, I could tell the solinoid was erratic in opening, and then quit.
I'd try investigating the parts manual of the stove and check out the gas valve.
danpik 07-17-2013 05:45 AM
I am sure that since this post is almost 2 years old the problem may be fixed by now.
